reset button in curves pane
roy
Postby roy » Thu Oct 04, 2007 8:02 pm
the reset button in the curves pane resets all curves, not just the one currently in view.  (e.g. if i'm looking at the R curve, reset button resets G as well).  Better if  relabelled "Reset All", and perhaps adding "Reset This" button too.  (I know its on the right-click menu, so not a significant problem, just a matter of usability)
Postby -default » Thu Oct 04, 2007 9:45 pm
Good point.  In actual use, I probably reset the individual curve more than I reset all of them, so this would be a good vote for changing the functionality of the button to affect just one curve
Postby mikemeister_admin » Thu Oct 04, 2007 10:46 pm
I like that idea, and since we can all dream, I would like to maybe hold down the alt key while clicking on the reset button and have "reset curve" change to "reset all" .
Gloria
Postby ggroess » Thu Oct 04, 2007 10:58 pm
Have a tool tip fly over the button telling me that..I'm getting older and I forget sometimes...
Postby -default » Fri Oct 05, 2007 7:45 am
Good ideas all - thanks.  These may or may not make it into the first release, but I've added them to my list.
Postby derekfountain » Fri Oct 05, 2007 1:18 pm
Hmmm, not sure about this one. That curves pane makes perfect sense: apply the curves, cancel these curves, reset the curves, show the RGB/Lab/Etc curves, and so on. Changing one of those buttons to apply to just one curve doesn't make sense.
Having the 'reset this curve' on the curves' context menu does make sense, and I have "Reset this curve" on a custom toolbar so I can hit it quickly.
So I vote against this one!
