Marks stay on masks screen
Postby derekfountain » Thu Oct 04, 2007 6:15 pm
I put a couple of marks and a sample point on an image and clicked Show Mask. The 10 mask thumbnails duly appeared, but my marks and sample all stayed on screen. The screenshot is attached.
Postby -default » Thu Oct 04, 2007 7:58 pm
Yes, that does look weird, doesn't it?  I'll see about suppressing the sample points when the "Mask Carte" is up.
BTW - good to hear from you.  I thought you might be too busy this week.
Postby ggroess » Thu Oct 04, 2007 8:07 pm
I don't recall mike but are you going to try to envoke the mask from this screen?
My first instinct is to double click on the sample and expect it to set the mask up in the curve window...
Postby -default » Thu Oct 04, 2007 9:42 pm
Yes, something along these lines.
Right now I'm thinking in terms of Gloria's suggestion to change the mask labels to buttons, or provide some other way to give you this functionality, and allow you to click on the one that you want.
Postby ggroess » Thu Oct 04, 2007 11:01 pm
Well if you control the screen you can set up transparent buttons.  Make the button the size of the square and then you got both...
Postby derekfountain » Fri Oct 05, 2007 1:29 pm
I found 30 minutes last night. And since it's Friday afternoon and the boss has already gone home, I can catch up on CM3 developments a bit from work! :D
