Week 04, Example 01 Lab 1
This board is for the September 2007 Curvemeister 101 class
Postby mikemeister_admin » Mon Oct 01, 2007 10:34 am
The first image uses the same control points as the RGB method used.
I found that I needed to adjust the b channel to get the best results.
The second image is using the highlight, shadow and neutral pin method.
I moved the neutral around to give the best results.
From memory I also increased the saturation as I feel it's best to adjust the neutral with full colour.
Regards
Postby ggroess » Fri Oct 05, 2007 12:24 pm
Lab 02 has the right colors..is this the image you used for the next version??
Users browsing this forum: No registered users and 66 guests
