When I am using PSE and CM3 with internet explorer open in the background...if I open CM and make some adjustments...then Click cancel because the crash bug is there...It closes CM3 but brings the Browser back to the front. Not PSE to the front as it should....Seems to be very repeatable...
Cancel does not return focus to PSE
