Workspace layout presets
Postby -default » Sun Sep 30, 2007 12:30 am
I'm think of copying Photoshop's workspace layout concept, where you can select from several layout presets: ribbon bar based, toolbar based, different docking locations for the pins and curve, etc.
If you have used the customization feature to set up a layout that you think might be of general use, please post a screen shot here and I'll include it, perhaps with modifications, as one of the presets.
Postby derekfountain » Sun Sep 30, 2007 2:46 pm
An example of my current layout is attached; you can call it the "prefers to use context menus" approach. :) I'd like to put the zebra mode button on the "Curves toolbar" but I'm not sure that's possible.
Postby -default » Sun Sep 30, 2007 11:28 pm
Thanks.  yes, I find myself using the context menus for nearly everything, but the buttons - and keyboard shortcuts - are nice for things you need to access easily.
I seem to have left Zebra mode out of the commands - I'll add it for the next release.
