Week 03, Example 05
This board is for the September 2007 Curvemeister 101 class
Postby mikemeister_admin » Sat Sep 29, 2007 10:39 am
Hello again
The biggest problem I had with this was knowing what colour the tinge was in the fur.
I tried setting highlight, shadow and neutral but found that I did better just setting the neutral and adjusting the a and b curves.
I assumed that the critter's eyes were red and adjuster the yellow to give a purer red without turning them into searchlights.
The tree trunk also looks a believable colour.
Regards
Postby ggroess » Sun Sep 30, 2007 1:51 am
He looks pretty good..the color to avoid in the fur is green.
Use the hue clock to check the dark parts of the fur for a green cast.
If you find one you need to remove it as much as possilbe.
The idea here is that in a lot of protraits with dark brown hair the trap is green.  It is usually slight and hard to catch.
