Window title
Derek, you're a mind reader. I put a fix for this into the latest version, but didn't mention it because it was not on the bug list.
Gloria is correct as well - if you change channels, or press ctrl-~, the correct window title appears.
LOL, I tried opening all sorts of files to see if it showed the filename for JPEGS or something. I couldn't get it to work; I thought it must be me!
