Having just fired up CM3 Beta I'm really pleased by the new version.
The wizard is neat, and I might find myself using it even though presumably I know how to do each of the specific commands individually.
The Color slider is hugely useful, much simpler than doing it by hand with the actual curve points!
I was tinkering with Masks and when setting Mask=None while the mask tab was displayed in a Lab image CM crashed and crashed PS CS3/Extended. I filled out the error report dialog, so hopefully that's been received.--David Cardinal
First Impressions: Very Cool!
Yes, the color slider is something I use all the time. You can also pin a neutral or other color and the a and b channels will rotate around that as the center point.
Haven't received the error report yet, but it's not unusual for this to take a while.
BTW - your time zone was set to GMT - I changed it to local time for California.
