Week 01, Example 05
This board is for the September 2007 Curvemeister 101 class
Postby mikemeister_admin » Thu Sep 13, 2007 11:11 am
Hello again
For my image I selected an underexposed section of photo of the chain drum of a canal bucket dredger.
I used the threshold method and only lab mode.
After bumping up the saturation a tad, I gave it a very slight nudge of contrast. You can barely see that the line is bent.
regards
Postby ggroess » Fri Sep 14, 2007 12:09 pm
Roo...
Good Job....
Here is another look at the image...I don't think it's any more right...Just a different look
I opened the midtones a bit and gave the green a slight increase on the A channel.  When I did that I started to get a blue cast in the greens so I gave the yellow a slight boost in the same area of the image.  Right click on the green leaves in the back and choose "mark" this will show you where you can adjust the curves...
Users browsing this forum: No registered users and 67 guests
