Posting Hints
This board is for the September 2007 Curvemeister 101 class
Postby ggroess » Sun Sep 09, 2007 5:56 pm
To attach an item to the posting click on the "Additional Options"  plus-ie icon.  You can attach more than 1 item to a post.
Please re-size your images to 800 X 600 with the highest quality setting you can use to keep the image below the 200kb restriction.
You can use the "Save as" functionality or you can use the "Save for Web" functionality to do this.  If you use the save for Web functionality you might want to include a screen shot of the curve you used on the image.  We can see the curve you used but if you are using Photoshop Elements and save for the web your curve is not accessable to us.
Please feel free to ask for help on any items you are confused about.
Thanks!
Users browsing this forum: Bing [Bot] and 1 guest
