Howard, session 3, example 6
Well, I figured out how to change the color of the car - I inverted the "a" curve in Lab mode.  I haven't figured out how to keep the grass green - yet.  Unless it is done through the use of multiple layers.  Is that the answer, or is the answer limited to the use of Curvemeister?  I'll keep working on this one.
						This can be done in 30 seconds with Curvemeister....
and the grass stays green...Start at the beginning and use LAB, Right click on the A curve and choose Pin Curve...
Let me know if you need more of a hint...
It can be done with layers but only if you worry about the tail lights and the sidewalls of the tires...some reflections can be fixed as well...
