wkg C1S1 example 1 Can't post image
I have been unable to post my work. I have saved Example 1 in photoshop elements, opened a "New Topic" (like this one), then clicked on the "Insert Image" icon to get two markers in the text area. When I try to insert my saved image file by going to it in my "Curvemeister" folder and using copy/past or drag/drop, the whole message page changes to the Curvemeister.com Home Page and my message is gone to the land of lost electrons or somewhere. I feel so dumb, but don't know what I'm doing wrong. Please help. Should I use the "Additional options," attachment option?
I had the same problem, so you aren't alone. You have guessed the next step: go to 'alternatives' and you will see where you will select your curemeister file that the image is in by using the 'browse' function. you will hilight example 1, for instance, and then open it and magic will happen. Think positive. Try it. I'm not certain I have the right size but I did, finally get something placed in this forum.
Flip
Flip
