posting picture question
This board is for the August 2007 Curvemeister 101 Class
Postby mikemeister_admin » Mon Aug 06, 2007 6:06 pm
  Am I doing this correctly?
    I started photoshop, brought the image into it and then selected Curvemeister from the Filter draw-down menu.
    The 1st time I worked with the 'wizard'. I then found I could cancel the wiz and work with the curve scale. I manipulated the curve to an acceptable image and 'saved' that. I selected the RGB rather than Labs.
      Now, I did not use 'pins' to set black, white, or neutral zones. Should I have done that?
      I do not see a button for sending an image. Am I in the wrong place.
Postby -default » Tue Aug 07, 2007 6:00 am
To set a shadow or highlight, start curvemeister, right click on the image, and select the menu item to create a shadow or highlight.
To post an image, you'll need to save the image in Photoshop, keeping the size under 180K bytes.  I find that jpeg at quality 5 works well.
Users browsing this forum: No registered users and 50 guests
