Week 3 ex 5
Worked in LAB, adjusted thresholds, boost saturation (a little) added lizard tail to bring out detail in highlighted fur. Used alt-click to add many hue clocks in areas that should be neutral. Made minor adjustments in a and b curves so that a and b points were all between -1 to 2. Checked in RGB...couldn't find any green in fur. sharpened.
First of all Good job...no discounting that...
but...
The green is in there...It's pretty deep but it's there...
Now you can fight all day long for it but you may have hit the dimishing returns portion of the program tonight...If you have a satisfactoy image and you still find a few greens in there don't panic...
The real reason for this image is to show you one of the problems with dark haired people...Green tends to creep into the browns and make them look odd...
but...
