this example was less tricky to me than the first one, I set the neutral using the hue clock, and then set the shadow, using the threshold. I enhanced the contrast fot the global image via the slider and then I adjusted the curve by moving the cursor on my image and select the matching points on the curves, then adjust the curves at these point the way I liked, looking at the image. Still not a scientific approach ;D
I failed to succeed on human figures I think
Used the Lab mode
example 2 Week 3 infinitech
Let's take it step by step from your image going forward.
From Shot3.jpg...
Set multiple hue clocks on the shadows so you can see where the image is in need of help.
Right click on the image in one of the blue areas and choose mark to set a reference point on the curve screen.
Shot4.jpg...
Below the mark you have right click on the curve and choose Pin>>Pin lower left / Pin Upper Right which ever side pins the yellow.
Expand the window so you can see where you are working...this close to the center of the curve you need lots of room...
Adjust the center of the curve until the shadows start to line up better...the sky will go a bit grey at this time...
Then Grab the endpoint of the blue curve and move it towards the center to saturate the sky.
Lastly re-threshold the image to brighten it up a bit.
From Shot3.jpg...
Shot4.jpg...
