donberl Week3 Example5
Postby mikemeister_admin » Sat Jul 21, 2007 5:42 am
Didn't understand the instructions about traces of green in fur. Again just adjusted in lab to what i thought looks ok.
Postby -default » Sat Jul 21, 2007 6:04 am
The traces of green are not easy to see, but the hue clock will point to the "G", indicating a slight green cast.  You have indeed gotten rid of it by eye, which is good.  It's also important to know for sure, and not rely completely on your eye to detect very small color casts.  This turned out well, though there is still an area of blank white n the lemur's forehead, and near his leg in the lower right.  Digital images are prone to this problem.  The detail in these areas can be brought out by making the lighter end of the curve a bit steeper.
