week 2 Example 6
Postby mikemeister_admin » Wed Jul 18, 2007 2:38 pm
I duplicate a layer, then, I turn the "a" curve upside down. I exit CM2 and used the blend if slider and turned the right side of the "a" slider left to bring back the grass. I then use similar method to bring the red color of the fence.
Postby ggroess » Wed Jul 18, 2007 3:06 pm
You got it...it was a long way to go but you got there....
Can you find a faster solution with far fewer steps??
Postby mikemeister_admin » Thu Jul 19, 2007 1:30 pm
Honestly, I learnt the trick from Dan Margulis. I have to use blend if slider. I can't find any simpler method.
Also, the rear indication lamps of the car shouldn't be green, so I revert them back to red and the corrected is attached below. :)
Postby ggroess » Thu Jul 19, 2007 4:33 pm
Well, Excluding the tail lights and the fence rail...
Try this...
The rest is window dressing...
Someone even used a mask one time and made the car plaid...
Users browsing this forum: No registered users and 58 guests
