week 3 Example 2
I set the endpoints using Lab, then I exit CM2 and enter CM2 again. I create a hue clock on the bright neutral and a hue clock on the shadow. I used wgCMYK to remove the blue cast in the shadow. I exit CM2 again and convert the file to Lab where I lock the neutral point of the "b" curve and then bend the blue part of the "b" curve anti-clockwise to creat a bluer sky.
