week 2 example 1 infinitech
Postby mikemeister_admin » Sat Jul 14, 2007 8:10 pm
here t is ..
done with the standard highlight/shadow/neutral and hue clock checking, for my taste a bit dark (except the skull)and some color cast on the meter that I still don't match with any close object.
Postby ggroess » Sun Jul 15, 2007 3:26 am
Good job on the color correction.  As you stated the image is a bit dark...You could re-open it in LAB and just adjus the Lightness, or you try a HSB adjustment.. There is the risk of adding color cast to the image in HSB...
See if you can brighten it up a bit...if you want to take the time...
Postby mikemeister_admin » Fri Jul 20, 2007 3:29 pm
here's a better one
To me there still a color cast but a green one (I can see it on the skull), MAybe, I must consider re profiling my screen as I stated that you see blue cast on "own image/week 1" that 1 posted wherever I see yellow cast (this is why I gave up.) But unfortunately I got a flat panel and no more color calibration device >:(
Postby ggroess » Fri Jul 20, 2007 7:49 pm
Well the color is actually there it is reflected from the duster...
Don't sweat it too much we really want to challenge you and these are some pretty tough images...
