week 2 Example 3
Postby mikemeister_admin » Tue Jul 10, 2007 12:40 pm
I set end points using threshold in Lab. Lock a centre point in the "a" curve. then, heavily bend the green part of the "a" curve anti-clock wise to bring out more green. I also bend the magenta part of the "a" curve slightly to increase red. I then rotate the "b" curve anti-clock wise. I steepen the L in mid tone to highlight to add contrast and finally sharpen the L.
Postby ggroess » Wed Jul 11, 2007 6:00 pm
Can you repost this as 800X600 I want to get a better look into the background....
Thanks!
Postby mikemeister_admin » Thu Jul 12, 2007 12:46 pm
Here's the resized photo.
Postby mikemeister_admin » Thu Jul 12, 2007 1:35 pm
I found my previous work not very satisfactory and I re-post a better version below.
Postby ggroess » Thu Jul 12, 2007 2:10 pm
Better no doubt...
the brightness is better as is the color.  Much better...
