week 2 Example 2
Postby mikemeister_admin » Tue Jul 10, 2007 12:20 pm
I set end points with threshold in Lab. Used multiple neutrals in RGB. Used CS3's shadow/highlight on the L to lighten shadow area. Rotate the a/b curves and finally sharpen the image.
Postby -default » Tue Jul 10, 2007 12:26 pm
You've done very well at removing the blue color cast,and bringing out tremendous amounts of detail and color.  Good job.  The final result is a little on the contrasty side, so perhaps blending this with the original image might give an image that is easier to look at.
Postby mikemeister_admin » Tue Jul 10, 2007 1:05 pm
Mike wrote : >>perhaps blending this with the original image might give an image that is easier to look at.>>
That's a very useful suggestion. I remember in Dan Margulis' book, he sometimes advise people to use additional layers and then reduce the opacity to taste. Thank you very much, Mike. :D
