week 2 example 1 - gus
Postby mikemeister_admin » Sun Jul 08, 2007 7:19 pm
I am having trouble posting this sorry if this is a duplicate. I am getting a file size error.
I used LAB color space - set highlight, shadow and neutral points ( I found that using the thresholds in CM was useful in identifying potential highlight and shadow points) - boosted saturation using slider - added contrast by raising 80% and lowering 20% point steeping L curve.
Appreciate any feedback on how this could be improved.
Postby ggroess » Mon Jul 09, 2007 4:17 pm
Gus,
If you look at the white square you will find a red cast over that part of the image.  This is a "classic" RGB image..Mixed lighting....
If you set multiple hue clocks on the image in the trouble spots, you will see what I mean.  Alt-Click on the areas you want to adjust and set up the hue clocks...then adjust the RGB curves to meet your goals....
Postby mikemeister_admin » Mon Jul 09, 2007 5:14 pm
Thanks for the feedback.  I'll give that a try.
