Gus Week 1 Exercise 3
Postby mikemeister_admin » Wed Jul 04, 2007 1:06 am
Used same basic method -- CM in lab, adjusted light and dark thresholds, adjusted saturation slider, sharpened with unsharp mask.
Question -- if I generate curves in lab mode and switch into RGB do the curves get "translated" into the new viewing space?
Thanks!
Postby -default » Fri Jul 06, 2007 9:31 am
This looks great.
No -there actually is no way to translate the curves.  However, if you set a shadow, highlight, and neutral point on the image, these will be carried over to the new viewing space.
Postby mikemeister_admin » Fri Jul 06, 2007 11:42 am
Thanks for your feedback and answers to my questions!
Gus
