Hi,
Here is my result for session 1 example 1:
Using sRGB Colourspace, I converted to Lab, then using Curves in CS3 moved 0 to 47 to increase the contrast in the shadows and 100 to 95 to increase the contrast in the high tones. Converted back to RGB and resized to 640x480.
I chose Lab adjustment to avoid colour shifts in RGB adjustments.
Comments?
Ken
Ken session 1 example 1
Greetings Ken,
When you made your correction in LAB did you notice the slider tool at the bottom of the CM window?
There is a saturation slider in the bottom of the window that is only present in LAB. You can increase the saturation by giving the slider a pull or by typing in the saturation numbers you want into the box to the right of the slider. What this tool is doing is rotating the A and B curves around the "Axis point" you created when you set the neutral. I use the term loosely.
Your particular image still has a slight blue cast. Check out the print screen attached and you will see what I mean. Take a look at your neutral, Grab the point with your mouse and move it around a bit and see if there is a better placement for it. Highlight and Shadow look pretty good...
