Week 3 ex2
overall the color and tone are good the problem area here is the blue shadows.
If you used lab you can adjust that out of the image by using a sharp bend in the B channel near the color on the curve. I would use the "bouncing ball" created by your mouse when you pass over the shadow. < the ball bounces on the curve line > to find the area of the curve you need to adjust. Then pin one end of the curve by right clicking and chosing "pin curve" adjust the area you want to adjust to remove the color from the image. You might have to play around a bit to get this one...
In effect you are adjusting only the Blue side of the B curve.....Keep asking questions as needed...
