Week 3 ex1
Postby mikemeister_admin » Mon Jun 18, 2007 12:13 pm
I edited this in RGB
Postby -default » Tue Jun 19, 2007 9:45 am
A little extreme with the deep shadows, but that's not a real problem.  Where I find this image lacking is the upper areas of the statues are very close to being blown out.  Try using some of the same mojo you used on the half dome image to darken the highlights, and add as much detail as possible to them.
