Class 2 ex 3 & 4
I like the shadow treatment for both the Bryce and moth images - you have a good touch there. Try also correcting the Bryce image in RGB Mode, and see if you can warm up the shadow areas to have a similar, or identical, hue clock reading to the stone formations that are in direct sunlight. The blue sky is too cyan - see if you can get it closer to the "B" on the hue clock, without crossing over into the zone of the purple sky.
The moth is good as far as color and neutrality go. There is not enough detail in the moth's head, though. See if you can shape the top of the Lightness curve to get a darker result that has more texture. - an example is available in the solutions for week 2.
