I used lab again on this picture,except this time did not use the wizard but instead used the curves graph.
By the way,what am I supposed to be putting in the options spots?
Joyed
class 1 ex.2
You need not use any of the options when posting..they really help you if you only want them...
The image looks pretty good...It is hard for me to see the shadow details because of the file size. If you can submit at the same screen size but up the quality until you get a 200kb file it would help a bunch...
Can you repost it??
Can you repost it??
