First picture with curvemeister
Hi Joyed,
Pretty good...It's a bit muted but a fair rendition...
Could you let me know what color space you did this in?
It helps Mike and I give you additional help to know more about how you got to this point.
Please also try to post the images as 800X600 so we can see the image better on the website...I usually download your image and open it in PS to figure it out but sometimes when you are looking for things fast it helps to be able to see it on the web.
THIS IS NOT A COMPLAINT BY ANY MEANS...
Hi Joyed,
I was having a little trouble navigatingyour website and when I finally figured it out I was anxious to get a picture in.I did this picture using lab as I thought it gave it a more natural look then using rgb
Hi Joyed,
joyed
well...With the LAB color space you have the saturation slider that you can apply to the image.
It is across the bottom of the CM window.
You are always welcome to ask questions about the site or how to do something. It can be a bit confusing at first.
Remember there are no real deadlines here..we are trying to get you going with the tool so if you need more time...take it...we have a full week for each assignment. I personally took the class twice when I started with curves 3 years ago...don't sweat it...
let me know what else you need and Mike or I will certainly try to help...
