Hi all
Many thanks for the assistance re posting pics. Hoping this works OK. Here are my first two examples. Not sure if I've achieved the best results but I am very impressed with the method. Cheers Bev
Bev Session 1 examples
Not bad at all, Bev. Your two images though are so similar that I wonder if you sent in two different sized copies of the same example.
Also, although I like the appearance, the brightest area of the house, the white square area below the leftmost black oval window is not pure white, but more of a gray. For the purposes of this exercise, which is to get a black shadow, and as bright a white as possible, that area should read RGB(255,255,255)
