Opened image in Photoshop CS3
Started up the Curvemeister plug-in and with the Lightness tab for LAB mode selected, set the Shadow point.
Switched to All Tabs view to observe the movement of all the curves, then steepened the A and B curves to increase the saturation of the image.
Compared results in RGB and LAB modes and decided to use the LAB mode since it represented what I thought were more accurate colors even though I also liked the RGB rendition because of its saturated Velvia look.
Suddie1215 - Week 1 Example 1
Thanks Greg.
I didn't spot the Saturation slider when I did this image; with my aging eyesight its difficult to see especially since it isn't labelled.
If I were doing this adjustment using Photoshop Curves, I would switch the blend mode of the Curves adjustment layer from Normal to Color to prevent the color shift.
