Good day, Firstly, when I open one of my downloaded images is PS CS2 I get an "embedded profile mismatch" message with 3 choices. What is the correct way to handle this? (Attachment 1)
My image: I firstly converted it to 16 bits/channel, then did Luminosity Masking (Earhbound Light) whereafter I played around in the LAB mode (see attachment). Lastly I sharpened with smart sharpen.
ganna
ganna c1s3 example 2
Ganna,
Look to the shadows...are they neutral or blue?? one of the thnigs you need to do to this image is get the blue out of the shadows while making the rest of the image look good...oh and the sky stays blue too....
I tried by putting a neutral point on the rocks, Lab values 50 0 0 All the blue disappeared, but fortunately I could put the blue sky back with the help of layers ;D (sort of cheating?) I sharpened. Although it is a bit light, the detail is still there.
Mike, thanks, I changed PS CS2 to sRGB.
ganna
If you move the neutral to the shadows you create a problem with the sky....You saw that...
Try this way of doing the correction. In B Channel of Lab or The B Channel of RGB find the part of the curve where the blue from the shadow is located and make a small adjustment to the curve to reduce the blue in that area. you should be able to remove the blue cast to the shadows without hurting the blue sky. Setting a neutral in a brighter part of the image will keep the tonal range in a better place and you should be able to work with the sky...
Users browsing this forum: No registered users and 62 guests
