Deb week 1, example 3
Postby mikemeister_admin » Wed May 23, 2007 2:29 am
Here's number 3.
Postby ggroess » Wed May 23, 2007 1:19 pm
Deb,
where did you set the shadow?
The reason I ask is it seems like the contrast is low...
If you set the shadow as a point rather than using the threshold, you might want to move the shadow point around a bit and see if there is more detail.  I would repeat the same for the highlight point.
If you used the thresholding by moving the edge of the CM window.  You may not hqave gone far enough.
Postby mikemeister_admin » Wed May 23, 2007 1:21 pm
I don't remember exactly, but I think I used the threshold. I'll play with it a bit more and see if I can get an improvement.
Postby ggroess » Wed May 23, 2007 1:43 pm
Let me know if you have any troubles...
Postby mikemeister_admin » Wed May 23, 2007 3:19 pm
Ok, here's a second try. It's a bit better in the dark areas.
Postby ggroess » Wed May 23, 2007 4:29 pm
Much better...
It also does not have that flat spot in the flower shadow...
G
