Benny Session 1 Example 1
Postby mikemeister_admin » Sun May 20, 2007 12:14 pm
Attached are RGB and LAB versions of the modified test image with chart.
I found, in both cases, there was very litle change from the downloaded original.
Turning the changes off in PS (to compare before and after) showed little difference.
Benny
Postby ggroess » Sun May 20, 2007 2:07 pm
Benny,
There is still some color shift in the RGB version (Shot shot 1 and 3)
The Lab looks better (Shot4)
