I am very much a beginner at this, so any and all feedback is appreciated!
-Joe
Joe - Week 1 Example 1
yeah that is about it...
If you watch the CM grid when you place a Shadow and Highlight it increases the slope of the curve.
You can effect some "local" changes after that to add contrast to specific tonal ranges. When we get to next week's assignments you will be doing some specific adjustments to help with those local controls.
Then we will add color control using the same techniques on separate color channels.
