Hello,
I saw today an unexpected behavior of the zoom function in CM 2.0. Trying to edit a panoramic jpg I found on the internet (http://woffi.de/tmp/powell.jpg), I find that:
1. in CM plug-in for photoshop CS2 the key Ctrl+Alt + and Ctrl+Alt - do not work;
2. when using the menu Zoom, I can magnify the image but after 2 or 3 steps, the image remains partially black.
This makes editing virtually impossible. It may be a problem with the particular jpg: that I don't know.
What do you think?
Strange behavior of Zoom function in CM 2.0
