LAB mode results look good here especially with the saturation option available.
RGB may be a little duller compared to LAB but this could be adjusted in PS or some other way in CM that I don't know yet.
Benny
Benny Example 4 Results
Hey Benny,
Good job again..I think you are getting things figured out quite well...
to improve the RGB image to the same level you need to apply a technique we are going to be discussing in the next week or so...the s curve...
Look at the attached image. try to apply a simular curve to your RGB image and see what you think.
Users browsing this forum: No registered users and 73 guests
