Hi Mike
What do you mean when you say "drag this point (ie set shadow or set highlight) around until you have broken up any solid areas of black/white"?
What does dragging the 'set' point around do?
thanks
Benny
Explannation please
Hi Benny,
Good question. This is done after you right click on the image to create the shadow or highlight, rather than the curves. As Greg says, there is a link to a pdf in the materials that explains how to "break" up the highlight or shadow areas.
I've also done a video that shows the procedure:
http://curvemeister.com/tutorials/Video/Shadow-Highlight-Neutral.avi
Good question - keep at it until we've given you a good answer!
