CM crashed, now won't open.
BBushe
Postby BBushe » Fri May 11, 2007 1:28 pm
hi mike,
I crashed curvemeister, and now it won't open anymore! Takes CS2 down with it.
here's what I did that originally crashed it:
had an image open in RGB and was looking at the channels in CS2. I had the blue channel selected and opened cm 2.4.2
realised that wasn't what I meant to do, so closed it, clicked on the 'RGB' channel and went to open CM again. BUT I accidentally clicked on the 'last filter' entry at the top of the filter menu, which was of course CM at the time. I guess it tried to repeat the last action, but that was only on a single chanel, when I now had all channels selected.
everything shut down and CM refuses to open now. I'll try re-installing now.
BBushe
Postby BBushe » Fri May 11, 2007 1:40 pm
re-install fixed problem. tried to re-create the issue, but version 2.4.4 seems to have fixed it already!
pff, if only you'd bothered to tell me you'd already fixed it...lol
bb
Postby -default » Tue May 29, 2007 12:28 am
Congratulations on fixing the problem yourself!
Again, I apologize for not responding earlier.
