Canyon Conumdrum
Postby ggroess » Mon Apr 09, 2007 1:32 am
Mike has asked me to shoot the image from a canyon that cannot be improved in LAB.
I know you all love a good challenge.
My best result is in RGB so far....
This image was shot at sunset it is a lengthy exposure....
Give it a shot...
Postby mikemeister_admin » Mon Apr 09, 2007 1:29 pm
I think you need a course in exposures!! - only joking Greg.
This is not the day to post a challenge and say Lab is impossible.
Just a quick fiddle only in Lab - I'll try later in the week when I have time as this is persumably not the effect you are looking for!
Chris
ianbowie
Postby ianbowie » Mon Apr 09, 2007 1:46 pm
My shot at it in Lab only.
Ian
Postby ggroess » Mon Apr 09, 2007 4:06 pm
The rock in the foreground is too blue.....Try it in RGB and set a reasonable neutral and you will see what I mean...
Mike's challenge to me was..."go on vacation and try to shoot an image of a canyon that cannot be improved in LAB."
90+ percent of the images I shot last week can indeed be improved in LAB...I found this one to be a real problem child...I will post my RGB later this week....
ianbowie
Postby ianbowie » Mon Apr 09, 2007 5:41 pm
I see what you mean ..... second try.....
Postby derekfountain » Mon Apr 09, 2007 6:17 pm
What are the characteristics of an image that make it unsuitable for correction in Lab mode?
Postby ggroess » Mon Apr 09, 2007 8:24 pm
Well for me it has been the fact that no matter what I do to it I cannot make it look like it should.  I cannot get rid of the yellow green cast when I set a single neutral.
It can be improved but When I use RGB I get much... much better results.
Postby derekfountain » Mon Apr 09, 2007 9:02 pm
Here's my fix. I also couldn't get anything decent looking from lab mode. Looking closely at the image with the aid of the hue clock, you can see there's a blue cast which gets deeper as the tones get darker. I think that's the key; the CM help text says that RGB is good at fixing problems where a colour cast is associated with a change in brightness, and that's exactly what we have here. I can't claim to understand the theory why that's true, but the curve shown below does get a decent result.
After the colour fix with RGB mode, I added another conventional pass in Lab mode to lift the brightness and increase the saturation. It's actually possible to lift the brightness to the point where it looks like a daylight shot, but since it was a long exposure sunset shot I tried to keep it a bit dark and saturated, like perhaps the view appeared at the time.
Postby ggroess » Mon Apr 09, 2007 10:53 pm
Derek,
That is where I got it in RGB as well...I like this one so far....
Postby mikemeister_admin » Tue Apr 10, 2007 7:58 am
I think that is absolutely excellent Derek,
I'm puzzled by one thing - I tried to copy your curves to see what was going on, and I noticed that I could not get the histograms to be anything like yours (see below), especially the red and green channels - so I guess you did at least 3 passes.  The first to lighten, then RGB, then Lab - is that right?
I had this problem on the course where I could not get my histograms to look like other people's - Mike suggested the difference between precise mode being on/off.
Does anybody else have this problem with histogram representation?
Thanks
Chris
Users browsing this forum: Bing [Bot] and 5 guests
