Hi,
I used to have it - but now it is gone.
I open up CM but when I click on pin - I do not get the pin palette displayed.
I know it worked before - may be only in the beta?
Any troubleshooting?
No pin palette
Hi Jean,
This thread is fine - sometimes it takes me longer to find a problem if it is added to an old thread, so when in doubt, create a new thread.
Pin Palette crashes are usually caused by problems with the .txt file defining the pins. If you know which pin file you had active - probably your paint samples, perhaps you could email it to me and I'll try to recreate the problem. This could also be a new problem with 64 bits only.
In the meantime you are OK with using the 32 bit version?
Ho yes, the 32 bits works fine.
The pins files where in the swatches folder witch is in the 64bits Program Data folder.
Some of them has the same name has the one in the goodies folder.
Jean
Jean
- oil_paint-txt
- (1.11 KiB) Downloaded 1002 times
- jeanpins-txt
- (303 Bytes) Downloaded 1065 times
- mytools-txt
- (89 Bytes) Downloaded 1040 times
- nature-txt
- (1.19 KiB) Downloaded 1012 times
- people-txt
- (474 Bytes) Downloaded 972 times
- pin-txt
- (1.53 KiB) Downloaded 1020 times
- shn_skin_tones-txt
- (1.97 KiB) Downloaded 987 times
