what is the latest version of der meister?
Postby mikemeister_admin » Mon Dec 18, 2006 1:55 pm
and how does one know which one one has?
Postby mikemeister_admin » Tue Dec 19, 2006 2:51 am
Hi.
  The latest shipping version is 2.1.1.5 and there is a beta version 2.2.0.0 . You can see your version at the top of the curvemeister screen when it is open.
Postby -default » Wed Dec 20, 2006 6:15 am
Barry is correct about the version number - I would add that if the version number does not show up, then you have a lot of new features to look forward too!
The other way to check is to use the Check for Updates command, in Start>Programs>Curvemeister.com, or in the Help menu of Curvemeister itself.
Postby mikemeister_admin » Wed Dec 20, 2006 4:36 pm
how does one "bata"?
