Can Curvemeister be installed on PSE 4 & PSE5 at the same time?
Postby mikemeister_admin » Tue Nov 21, 2006 12:07 am
I have just installed PSE5 and until I learn to use it do not want to delete PSE4 off my computer.  Am I able to install Curvemeister on PSE5 while still having it installed on PSE4?  I started to do this and a box came up that informed me I should not have it installed twice on the computer.
Sorry for this question but I'm not real confident in the inner workings of my computer, LOL.  Any help would be appreciated.
Paulette
Postby ggroess » Tue Nov 21, 2006 12:21 am
Paulette
Yes it can....
Make sure you install it to the Plugins folder of both versions....I would just go ahead and remove PSE 4 and start from scratch on 5.  It will remember all your tags and stuff.. The DB is faster, leaps higher, and is new and improved with brighter whites and your colors look great.....
Postby mikemeister_admin » Tue Nov 21, 2006 12:58 am
Thank you so much Greg.  I know that PSE4 should be un-installed, but I'm old and afraid of change (smile).
Paulette
BBushe
Postby BBushe » Thu Dec 07, 2006 7:10 pm
does that mean I can wash my clothes less often??!! :)
Postby ggroess » Fri Dec 08, 2006 4:40 pm
Well you can but I bet people would talk.  I just finished as a Beta for 5.0 when that note was written.  The program is near and dear to my heart.  But even I hate the 4.0 version...ok..hate is kinda strong...there were significant regrets when the 4.0 beta closed....
Postby mikemeister_admin » Sat Dec 09, 2006 12:38 am
  I just read an article in "Photoshop creative" describing the new PSE 5 and it's "Adjust Color Curve" feature.  How does it compare to curves or curvemeister?
        Barry
Postby ggroess » Wed Jan 17, 2007 5:36 pm
Barry so sorry to be so late with this...
Let's just say the Curvemeister is staying on my PC...
PSE gives you a set group of curves and you apply a "stock" curve to fix specific issues.  I personally did not like it but i had the freedom of Curvemeister to compare it...
Users browsing this forum: No registered users and 50 guests
