Question for uploading images to personal gallery-help
Postby mikemeister_admin » Sat Jul 01, 2006 12:49 am
1. I have tried a half dozen times to upload images into a personal gallery. The image  comes up and it asks what area of the "challenge" gallery I want to enter it into. I continue to end up in this same spot. Does anyone have the answer.
2. It appears that only 2 images at a time is uploaded. Is that correct?
Thanks Joe S
Postby mikemeister_admin » Sun Jul 02, 2006 6:40 pm
I have only done this once and have added( 10) photos to it after. You have to go to the gallery  and under, Create/order my album, create your own gallery. This gallery should how on a list for you to select when you want to load photos. As far as two at a time, Mike has another way of doing it, but I have not tried it.
Postby -default » Sat Sep 16, 2006 2:17 am
Here is a link to the help page for uploading images to the gallery.
http://www.curvemeister.com/coppermine/docs/index.htm#upload_http
If you are using Windows XP, there is a more convenient way to upload multiple images, using the web publishing wizard.
http://www.curvemeister.com/coppermine/docs/index.htm#xp
BTW - The gallery and the forum are separate from one another.  Uploading images to the gallery is a different animal altogether than attaching images to your posts.  This uses a different procedure under "Additional Options..." below and to the left of the window you type your text into.
