Window sizing - losing the toolbar
Postby mikemeister_admin » Fri May 26, 2006 9:24 am
Hi, purchased CM (ver 2.1.11.0) after studying Dan's LAB book. CM certainly speeds up the initial improvements!
I lose access to CM's toolbar if I have the image window maximised in CS2, palettes tabbed off, then start CM. (this gives me the max amount of work area).
CM appears to work within the CS2 image window (makes sense) , however if the image window is maxed and  palletes are hidden it buries the top of its window under the CS2 menu bar, thus hiding CM's toolbar, and because the window is maximised, I can't get to the min/max buttons, so I have to close CM!.
Can't see this listed as a "fix" in the later versions.  Any suggestions?
Also, if I  max the CS2 image, and leave palletes on , they pallets stay on top of CM, !
Cheers  Brian S
Brian S
Postby -default » Sat May 27, 2006 9:42 am
I'll recreate the problem and see about a software change to fix it.  My first thought is to make the window smaller if necessary to leave room for the tabs.
