A couple of days ago I spent some time playing around with the GrowCut Mask and Extract plugins.
http://research.graphicon.ru/image-processing/gml-growcut.html
These are an alternative to Photoshop's Extract function and help to separate an object from its background. They work quite well, and are a lot of fun to learn because of the in terractive display. It's fun, but hard to describe how the image comes alive in a liquid sort of way as you select different areas
These should work with Elements as well as Photoshop.
GrowCut plugins - fun freeware for background extraction
first I was glad, and perhaps in the future, I am glad, but on the moment not.
I have experimented the whole evening on the 2 plugins, where are .8bs and not .8bf.
They worked till I click on the end ok.
The real result is a black and white mask and not a extraction.
I know how it worked with photoshop 7 and I know how it worked with photoshop elements 4.0.
But the result is not so, as bescribed in the plugin manual.
you know a solution to that.?
I am also studying the masking in the hidden powerelements 4.0 which I have.
Perhaps a combination of these two can lead to a result ?
Try running it from the Select menu instead of the Filter menu. The result will be a selection instead of a mask, and you can then copy and paste the resulting selection.
you are right, it worked on that way.
I have never looked at the Select segment.
Now I am glad.
In the evening I go experimenting again.
P.s. very very much thank you. Also for the plugin-tip.
I have used GrowCut extract and it works better than P.S.E 4.0 and also photoshop 7.0 which I have used a while in the early days.
I can now do a extraction, and at the same time make al layer mask with all the old information still there.
anf of course , I can ad several backgrounds, if I wish.
Nice, its nearly the old Photoshop for photografy.
