When working in a curve window, I will often go and hit the compare button. Now to get back to the curve you were adjusting, you have to go through a series of key strokes or actually click on the curve again... OR
MAYBE I havent read all the docs...
Thanks,
Matt
Current Curve Window to be STICKY
Thanks,
Matt
Matt, when you click on the compare button, you must hold the button.
When you losen the compare button, you return automaticly to the visible position before clicking the compare button.
When it is not so, then there is something wrong in you system or programs.
Close all programs, else photoshop and curvemeister, and try again.
frits
I think I understand what Matt is saying.
If you are using the arrow keys to move points around, for example, and you press compare, the focus moves to the compare button. To move the points around again, you need to click on the point in the curve window. Is this right?
I have tried what you said. It looks normal to me!!
If I understand correctly, this would be a new feature that would allow the compare functionality to be used, while retaining the currently selected curve and point within the curve.
One way to do this would be to re-instate the "C" key as a way to activate the compare function. I had this feature for a while, but removed it because the key repeat feature got in the way.
[thats EXACTLY what I mean, would be real time saver if it just went back to the axis number you were adjusting]
[You just beat me to it, I was going to suggest using alt+c or what you said, just press c . For some reason it is a large time waster having to go bac all the time. Maybe I am just strange.. thanks for your time...]
[While I am at it, was moving a selected point, neutral, around with the cursor keys... when you hit compare, you have to reselect the point in the image, could the same 'sticky' feature apply to just what ever you are doing in an image or a curve, when you hit the compare button...??? I find it impossible to ACCURATELY and PRECISELY reselect where I was...]
