Show some of your work.
Postby imported_artmar » Wed May 15, 2013 12:25 pm
Hi Tanja,
Thanks for your comments and suggestions.
Yes, the church needs some work, or some work undone I should say. The first photo is the OOC JPEG, with neutral settings, the second the RAW file with my (attempted) enhancements. So, I can't blend them, but could desaturate the second image to some degree and blend it with the first with a mask. But I do like the colour differentiation in the stonework of the church in the second version, although the red-orange patches definitely need correcting. I'll see what I can do along those lines.
Postby ggroess » Wed May 15, 2013 12:51 pm
Art,
Try this...
Take your image into CM and create a L channel mask as shown.  Then do the color moves; the bell shaped curve should hold off some of the super saturated colors for you.  Play around with this or an inverted version of it...
capture-jpg-31
capture-jpg-31 (307.25 KiB) Viewed 53591 times
Postby imported_artmar » Wed May 15, 2013 8:37 pm
I corrected the red-orange patches in the church with a combination of  a CM mask and PS layer mask.
I inadvertently chose the even more saturated version to begin with, so the plant colours here have shifted England toward the tropics! But I'm into it, for now.
cricket-st-thomas-church_3-jpg
cricket-st-thomas-church_3-jpg (208.46 KiB) Viewed 53591 times
Postby imported_artmar » Wed May 15, 2013 8:48 pm
A slight variation: Forgot that I had meant to brighten it a tad.
cricket-st-thomas-church_4-jpg
cricket-st-thomas-church_4-jpg (273.37 KiB) Viewed 53591 times
Postby imported_Tanja » Wed May 15, 2013 9:13 pm
Looks good! I prefer the fist one.
Postby imported_artmar » Fri May 17, 2013 10:37 am
Thanks Tanja -- in a month or so I'll revisit this image and probably desaturate the foliage a bit.  But I have to gain some distance from it.
Postby ggroess » Fri May 17, 2013 7:23 pm
Here is my swing at this...I used an action I have that creates a butterfly comparison so you can see them side by side...
This is using the techniques I have shown over the course of the class, color expansion was through a R channel mask that had been curved to reduce the reds.
Inverted R channel with a bell curve.
Sharpened using PPW sharpening.
cricket-st-thomas-church_butterfly-jpg
cricket-st-thomas-church_butterfly-jpg (301.18 KiB) Viewed 53591 times
Postby imported_artmar » Fri May 17, 2013 7:34 pm
Thanks Greg, I'll give that a try.
Postby imported_Tanja » Fri May 17, 2013 11:54 pm
Know what you mean and I hate it  :D.
Some pictures correction works right now and some needs time.
I love the first ones  ;D
