1) expiration was inadvertent
2) Check the version and see if you have the latest beta version I think the expiration issues were resolved by Mike a while ago.
3) I believe that 3.0.16 is the latest version yes.
4) I am running the 3.0.19 version and so far so good...I'm going to jump onto the 64 bit version soon I too have had issues with it. You can try it if you want...Actual mileage may vary
Curvemeister 3.0.18 is available
Hi Julie,
I'd stick with what's working for the time being. The main reason to upgrade would be if you were interested in using the 64 bit version of CS4.
Problem is its not all working as it should. My hue clocks in CMYK do not function at all No number and no arm. I also cannot add any pin files. I can open them and use them but when I close curvemeister it cannot save them. So what would you recommend. As i said before I'm not an expert on computers so please keep instructions simple
thanks Julie
