Canyon Conumdrum
Postby -default » Tue Apr 17, 2007 9:36 am
I do like the canyon colors.  You're right the sky is too green - this may call for a mask.
Postby mikemeister_admin » Tue Apr 17, 2007 9:43 am
indeed!
but I doing two yobs,  in fact three.
first , On my right site the computer is finished with rendering a DVD film.
So i must set another one.
After that, I must going om with the new version of CM and the canyon and third, i must bring my grandchild to the school about 13:00h ( local time is now 11: 43 H)
So I am busy you see!
So I thrown away the commercials now and going on with rendering the "The Italian JOB" to a DVD
Postby -default » Tue Apr 17, 2007 9:47 am
I can see you are very busy.  It is time for people in California to go to sleep and leave all the hard work to Frits!
Postby mikemeister_admin » Tue Apr 17, 2007 9:50 am
sleep Well mike!
how many hours are between California and Holland?
I thought  about 9 hours.
So you are very late!
so going on with the new CM. till now no problems.
Postby mikemeister_admin » Tue Apr 17, 2007 10:13 am
doing a mask.
but the hue clock said it is still on the green site.
Also did a saturation of 1.20 in Lab mode.
I going on!
Postby mikemeister_admin » Tue Apr 17, 2007 11:30 am
doing again masking!
the problem is that I not control the masking very good.
I must have it from the hidden Power of P.S. E. 4.0/Powermasking in P.s.e 4.0.
So I did colormasking and set the hue a little.
I will try or another masking technics does it better.
I have seen there are details in the sky, and for now , I losing this by masking.
Postby mikemeister_admin » Tue Apr 17, 2007 12:18 pm
So doing it now with GML.
then it is easy and I could satisfy each mask-
also the clouds stay there.
for this moment it is the final solution, till I found other masking technics to do it better.
Postby mikemeister_admin » Thu Sep 04, 2008 2:04 pm
Here are two alternatives of mine, using my new Linear Light Flat Curve technique (needs a better name).
Postby mikemeister_admin » Thu Sep 04, 2008 3:08 pm
And here's a bit redder one (some sky noise that would obviously be removed in a more important image):
Postby mikemeister_admin » Thu Sep 04, 2008 3:32 pm
Thought I'd have a play as well !
Jacob, what would be interesting is if you could also submit your curves - that way we all quickly learn from our betters!
My rendition is a single pass with an added 66% Lab sat adjustment to enhance the colours.
I am really very impressive for a single pass with this new method, but I could not get rid of the magenta cast on the far rim and keep the sky.
